Blast from the past :
Also,the IEE’s " Design participants notes " for the 16thEdition BS-7671: confirms that if an RCD is selected to provide indirectprotection, it is not necessary to undertake the disconnection calculations required for Overcurrent devicesbecause the RCD will always trip within 0.2 seconds
( An RCD will trip in 0.04s , under Earth-fault-conditions ) compared to 0.2 seconds
17[SUP]th[/SUP]Edition : Chapter 41 Directcontact now refers to basicprotection and indirect contact is called fault protection
Re-cap :
( RCD operation for Non-time-delayed ) BS-EN-61008-1 . BS-EN-61009-1 … (Part-1 ) :icon_bs:
Table 41.1. gives the maximum-disconnection-timesfor final circuit(s) Not exceeding 32A , of varying nominal-voltages forming part of an ,installation being ?? TN- or TT- system ( Earthing )
P/57 . 411.4.9. States :
That where an RCD is used to meet therequirements of 411.3.2.2. To providethe required disconnection time , the maximum values ofearth-fault-loop-impedance in Table – 41.5 may be applied
The maximum permissible earth-fault-loop-impedance ( Zs ) to ensure ( RCD operation for Non-time-delayed ) ◄ RCDs protectingfinal-circuit(s) Notexceeding 32A are given in Table 41-5 .
Disconnection times required by Table41.1. ( Whether ) Protective-device(s) Fuses , Circuit-breakers , RCDs / RCBOs
2392-10 : in your Understanding .
There is NO requirement toconfirm that the required disconnection time can be ( Achieved ) bytesting the protective-device / (s) .
You are confirming the , Earth-fault-loop-impedance ( of the Protective-circuit ) does not exceed the relevant tabulated maximum earth-fault-loop-impedance , for the Type / Sensitivity of the ( Protective-device)
Reactions: 1 person
Old to New : BS /BS-EN :icon_bs:
Operatingtimes of residual current operated devices (RCDs) to satisfy the relevantrequirements for automatic disconnection of supply given in Chapter 41 of BS-7671:
2008.According to Chapter 41, RCDs may provide faultprotection and /or additional protection.
RCDs to BS 4293: 1983 were first introduced into the Wiring Regulations bythe 15th Edition.
The harmonised standard BS EN 61008-1:1995, which superseded BS 4293: 1983, was introduced by Amendment 1 to the 16thEdition (BS 7671: 1992). The same amendment also introduced socket-outletsincorporating RCDs to BS 7288: 1990, portable RCDs to BS 7071: 1992 and RCDsincorporating overcurrent protection to BS EN-61009-1: 1995 (Regulation412-06-02 referred).
Whenthe 17th Edition (BS 7671: 2008) was published, Only BS EN 61008-1 and BS EN61009-1 were still listed (Regulation 411.4.9 refers).
However,this does not preclude the use of RCDs to BS 4293, BS 7288 and BS 7071, whereappropriate, for fault protection and/or additional protection, provided theymeet the relevant operating time requirements.
Reactions: 1 person
2392-10 : This is just to referyou to some studying .
P/33 .. Residual-current :
Algebraic sum of the currentsin the live-conductors of a circuit at a point in the electrical-installation .
p/34 .. Residual-current-operated-circuit-breaker ( Without ) integral overcurrent-protection ( RCCB )
p/34 .. Residual-current-operated-circuit-breaker ( With ) integral overcurrent-protection ( RCBO)
4 terminals (2 top, 2 bottom)
( RCCB ) RCDnot RCBO ! BS-4293 RCD
Therefore the circuit connectedto it in theory has no Over-load-protection.
Reactions: 1 person
Where an RCDis employed to achieve the disconnection time required by Table 41.1, it isnecessary to satisfy yourselves that the maximum earth-fault-loop-impedance (Zs) Statedfor a , particular sensitivity of RCD inTable 41.5 is not exceeded in the circuit to which they provide-protection .
Reactions: 1 person
Re-cap :
BS-EN-61557-6 , has requirements’ forthe following tests to be ( Appliedto RCDs )
Non-tripping ( 50% / 0.5 ) test
□ Tripping ( 100% / 1x ) test. C&Gs ... RCD 100mA tested at 100% . 1x BS-EN-300mS . Scenario TT – system .
▲ ( 100mA ... DoNot Test at 5x times rating ) This is what C&Gs want to hear .
Theregulations apply to the Design, Erection and Verification of any electrical-installation
5 I∆n ( 500% ) test
2392-10 ... These two are the ones you will Use / Fast trip
Reactions: 1 person
2392-10 : Locations containing a Bathor Shower
Regulations – 701.411.3.3. P/199 “Additional-protection
Shall be provided for all ( Low-voltage-circuits of the location ) by the use of one or more having the ,characteristics specified in , Regulation 415.1.1. P/66
Note : also regulation 314.1. (iv) 531.2.4. concerning avoidance of ,unwanted-tripping Etc .
Regulation – 415.1.1. P/66
The use of RCDswith a rated-residual-operating-current ( I∆n ) not exceeding 30mA & an operating time not exceeding 40mS ata residual-current 5x I∆n is recognised in A.C. systems as additional-protection in the eventof failure of the provision for basic-protection and / or the provision for fault-protection or careless by Users .
Reactions: 1 person
2392-10: Domestic – installations
Note : BS-7671: definition of ( Wiring-system )
Does not include lights, but in mostcases the opening made for lighting would be larger and more onerous than openings created for cables.
BS-7671:2004:2008: 2011 : definition of ( Wiring-system ) P/36
An assembly made upof Cables or busbars and parts which secure and, ifnecessary, enclose the cable or busbars .
Reactions: 1 person
2392:10 . Designer(s) Installer(s) , first of all you have to decide what you are trying to Achieve & Why.
The O.S.G. section3 . P/25 Guidance :
The requireddisconnection times for TT – systems can ( except in most exceptional circumstances ) Only be achieved byprotecting every-circuit with an RCD .
Electrode-résistance inTT – system(s) 411.5.3. P/57
The Regulations requirethat the earth-résistance at the electrode ( Ra or Zs ) be as low as practicable . Table – 41.5.
States that: 41.5. specifies a maximum-résistance required for a ( 30mA RCD ) to comply is 1.667Ω *
Note 2 : * The résistanceof the installation earth-electrode should be as low as practicable .
Note 2 : A valueexceeding 200Ω may not be stable .
RCD / 30mA earth-current would trip the device within the required ( 0.2s ) conditions comply with 411.5.3.
Fault disconnectiontimes for, TN – TT – systems
BS-7671:2011: specify the requirements forAutomatic-Disconnection of Supply . byprotective-device(s) circuit-breaker(s)of a fault occurring .
BS-7671:2011: disconnection time ( fault’s Occurring )
BS-7671: have statedthe facts . Type of Earthing-systems ?? You , decidewhat you are trying to Achieve & Why.
P/53 , Regulation 41.1. “ Stipulates “ Maximum-disconnection-times
Typeof Earthing-systems
Circuits rated , 32A or less , TN – installation(s) must disconnect within ( 0.4s ) 400mS
Circuits rated , over 32A , TN – installation(s) must disconnect within ( 5s )
Circuits rated , 32A or less , TT – installation(s) must disconnect within ( 0.2s ) 200mS
Circuits rated , over 32A , TT – installation(s) must disconnect within ( 1.0s )
2392-10 : Where does BS-7671:2011: “ Start “
Metal-clad or Plastic all insulated consumer-unit ? What makes thedifference in the eyes of BS-7671:2011 & O.S.G.
Re-cap : 2392-10 : P/29 / O.S.G. The Enclosures of RCDs
Or consumer-units incorporating RCDs in TT – installation(s) should have an ( All-insulated or Class-11 construction oradditional-precautions )
Out of curiosity, Whydoes an RCD allow for a ( Zs of 1667Ω ) P/57 / Table 41.5.
[ I = V/R , R = V/R , 50V maximum-touch-voltage ] / 0.03 ( 30mA ) = 1667Ω :
50V ÷ 30mA = 1.666666667Ω [ round – up to 1667Ω ]
[ 30mA ÷ 1000 = 0.03A]
O.S.G. P/23, ( Protection)
Firstly : Type of protective-devices
The consumer-unit ( or distribution-board ) contains devices for the ( Protection) of distribution-circuits & final-circuits against .
• Overload .
• Short-circuit .
• Earth-fault .
2392-10 : Circuit-breaker & RCBOs don’t stop at , BS-EN.
Stillout there . ( Overload-protection ) BS-3871, O.S.G. P/23
Appx 3 , 533.1. Overload-protection will be provided by the ( Use) of any of the following devices .
Fuses to BS-88-2 , BS-88-3 , BS-88-6 , BS-1361 & BS-3036 .
Under the 16[SUP]th[/SUP] Edition they where called this , Miniature circuit - breakers to BS-3871-1 types ( 1 , 2 , & 3 )
Circuit-breaker(s) to BS-EN-60898 types , B , C , & D .
Residual-current-circuit-breaker(s) ( With ) integral-overcurrent-protection ,RCBOs, to BS-EN-61009-1
Reactions: 1 person
Any & Allsuch liability is disclaimed .
GN-3: All parties must rely upon their ownskill & judgement when making use of them . ( Use as a guide / Guidance Only )
O.S.G.: All parties must rely upon their own skill & judgement when making use ofthem . ( Use as a guide / Guidance Only)
P/25 Competent-person:
A person who possessessufficient technical-knowledge, relevant practical skills & experience forthe nature of the electrical-work undertaken & is able at all times toprevent danger & , where appropriate, injury to him / herself & others .
BS-7671:2011: All parties must rely upon their own skill & judgement whenmaking use of them .
2392-10 & any Electrician takes responsibilityfor there OwnAction . ( in Our case here Moral-responsibility )
Reactions: 2 people
Operation of the Test-button . The Why’s
Tripping of the RCD in response to operation of the ( Test-button ) does NOTverify that the RCD will provide protection “ Additional-protection “
“ Verification “ 2392-10
P/36 , All measures by means of which compliance of the electrical installation withthe relevant requirements of BS-7671:are checked :
Inspection .
Testing . Verification of the ability ofthe RCD , to provide-protection can only be ( Assured ) by Testing :icon_bs:
Certification.
Reactions: 1 person
RCDs - Testing can be done from any point of the circuit ( e.g. socket-outlet ) or at the outgoing-terminals of the RCD itself.
Prospective-fault-current. 2392-10 .
612.11. ... ( PFC ) is a generic term .
Either :
( PSCC )prospective-short-circuit-current .
( PEFC ) prospective-earth-fault-current.
Reactions: 1 person
Some facts 2392-10 . RCD - Tests: :svengo:
Where RCDs ( form ) part of the installation,
Whether , they are for Fault-protection of Additional-protection or both ,
The requirements’ of Regulation(s) 612.8.1. & 612.10.respectively that such devices must be Tested .
This test is in ( Addition ) to the test carried out bythe use of the manual-test-button incorporatedwithin the RCD .
Reactions: 1 person
( half-cycles & 180° ) ◄ 2392-10. 2394 . relying on the Megger on Auto . Your marks are costing you money. Yeah Pass or Fail .
GN-3 . P/58 . Operation & functional-testing of RCDs :rant:
The operating times of RCDs are required to be ( Tested) in the following circumstances
612.8.1. ► where they are relied on for disconnection for compliancewith Chapter - 41
612.10. ► where they are installed as additional-protection asspecified in Chapter - 41
Where RCDs areinstalled with circuit-breakers and the circuit has the characteristics to satisfy Chapter – 41without the RCD, then testing of the RCD is not essential unless it is specified for , Additional-protection .
C&Gs . 2392-10 & 2394 . on Exams .
Operation of RCD
411.4.5. ◄◄◄
for each of the ( Tests ) readings should be taken on ( Both positive & negative half-cycles ) and the longer operating-time recorded . ( mS) ( half-cycles & 180° ) ◄
Do we have anEarth ??
► Prior to these RCDs - tests it is essential ,for ( Safety-reasons ) thatthe earth-loop-impedance is tested tocheck the requirement’s have been met.
2392-10 / 2394 . You are :
Verifying protection by automatic supply disconnection
GN-3. P/59 Additional-protection 415.1.
Where an RCD with arated-residual-operating-current, I∆n not exceeding 30mA is used to provide Additional-protection inthe event of failure of basic-protectionand / or the provision forfault-protection or carelessness byusers, the operating time of the device must not exceed 40mS when subjected toa test-current of ( 5x I∆n ) the maximumtest time should not exceed 40mS , Etc
415.1.
612.10. Additional-protection
The verification goesthe effectiveness of the measures applied for Additional-protection is fulfilled by ( Visual-inspection )&( Test )
Where RCDs are requiredfor additional-protection,
The effectiveness ofautomatic-disconnection of supply by RCDs shall be verified usingsuitable-test-equipment , according to BS-EN-61557-6 , see Regulation – 612.1.to confirm that the relevant requirements in Chapter 41 are met .
In the eyesof BS-7671:2008/2011:
612.9. Before ( Circuit-loop-impedance ) Earth-fault-loop-impedance .
612.10. After .
Anearth-loop-impedance-test will measure the resistance offered to the flow ofcurrent in the path that a fault current would take from line to protectiveearth. This resistance must be sufficiently low to allow enough current to flowpast to trip the circuit protective device in place, a Circuitbreaker or something else.
Inspection &Testing .
As GN-3 reminds us . The inspector to be fully-versed in the ( Capabilities& Limitations ) of instruments &be aware when a test is likely to createa dangerous-situation . Regulation -610.1. Your testing , not lead to persons or damage to property orequipment during Inspection & Testing .
Even when the circuitbeing tested is ( Faulty )
632.4. Defects or omissions revealed during , inspection & testing of the installationwork covered by the certificate shall be made good before the Certificate isissued .
Check list : Fused-connection-units .
Re-cap . that require Visual-inspection . prior to carryingout Testing . :icon_bs:
Suitably-fused , whereappropriate . 433.1.1. 434.2.
BS-7671:2011; & GN-3 . wouldany of this come up on Exams . ( Everytest has it’s Merits ) :icon_bs:
C&Gs / GN-3,Stipulates that, The installation must remain isolatedfrom the ( Supply ) until alltesting has been completed & the earth-electrode connection-reinstated .
C&Gs / GN-3,Stipulates that, This disconnection will ensure that thetest-current Only passes through the, earth-electrode and not through any ( Parallel-paths )
( Where-required )
Re-cap : 612.7. Earth-electrode-résistance.
BS-7671: Stipulatesthat where, earth-electrodes are usedthey should be tested. BS-7671: Electrode-resistance to Earth shall be measured
If the electrode under test forms part of the earth-return for a TT – system in conjunction with an RCD, GN-3 describes the following method(s) .
• Disconnect theinstallation-protective-equipotential-bonding ( equipotential / equal bonding ) from the earth-electrode to ensurethat the test current passes only through the earth-electrode .
• Switch off the consumer’s unit to isolate theinstallation
• Using a Earth-loop-impedance-tester, testbetween the incoming line-conductor and the earth-electrode . BS-EN-61557-3 Instruments conforming .
• Reconnect : theprotective-bonding-conductor(s) when the test is completed .
Record the results on a, Schedule of test-results , accordingto Appendix - 6 , BS-7671:
GN-3 : stipulates that, that an acceptable value for the measurement of the earth-electrode-résistance, would be less that 200Ω .
BS-7671:2011: P/57 . Table 41.5 . Note – 2 *: The résistance of the installationearth-electrode should be as low as practicable. A value exceeding 200Ω may not be stable. Refer toregulation 542.2.4. The type & embedded depth of an earth-electrode . Etc
Supply Connected .
Testing earth-fault-loop-impedance :
Your object of this test is to ( Verify) that the impedance of the whole ( earth-fault-current-loop ) islow enough to allow the overcurrent-protective-device to operate within the disconnection timerequired Stated in BS-7671:2011: in our case here Table 41.3. RCBO / Circuit-breakers .
P/36 . Verification : All measures by means of which compliance of the electrical-installationwith the relevant requirements of BS-7671:are checked .
Comprising . Inspection , Testing & Certification .
“ Competent-person “
612.9. Earth-fault-loop-impedance . ( 2392-10 , Circuit-loop-impedance )
Where protective-measuresare used, which require knowledge of earth-fault-loop-impedance, the relevant-impedancesshall be measured .
GN-3 . Re-cap . Protection by automatic-disconnection of supply . P/51.
The effectiveness of measures for fault-protectionby ( ADS ) can be verified for installation(s) with a TN – system by :
• Measurement of earth-fault-loop-impedance .
2392-10 , Reason :- youhave confirmed that you have an Earth before testing your RCDs / RCBOs
• Confirmation by visual-inspection that , overcurrent-device have suitableshort-time or instantaneous tripping setting forcircuit-breakers,
• where RCDs are employed, testing to confirm that thedisconnection-times of Chapter 41 . of BS-7671:can be met .
RCDs :- Residual - dual / Line & Neutral-conductor(s) Two / dual in Balance :rant:
Reactions: 1 person
( T ) . One of the most important regulations - 632.4. P/196 . Defects or omissions
Revealed during inspection & testing of the installationwork covered by the Certificate shall be made good before the Certificate isissued . :icon_bs:
Periodic Inspection ( Electrical-installation-condition-report ) EICR .
P/195 . 621.3. Precautions shall be taken to ensure that the periodic-inspection &testing shall not cause danger to persons or livestock & shall not causedamage to property and equipment even ( if the circuitis defective )
• Measuring-instruments & Monitoring-equipment and methods shall bechosen in accordance with relevant-parts of BS-EN-61557. If other measuring-equipment is used, itshall provide no less degree of performance & safety .
Measuring-instruments& monitoring equipment and methods shall be chosen in accordance withrelevant-parts of BS-7671:2011: plus –GN-3
P/195 . 621.4. Theextent and results of the periodic-inspection & testing of an installation,or any part of an installation, ( shallbe recorded )
P/195 . 621.5.Periodic-inspection & testing shall be undertaken by a , Competent-person.
631.2. Upon completion of the periodic-inspection& testing of an ( Existing-installation) an Electrical-installation-condition-report , based on the model given inAppendix – 6, shall be provided .
- such documentation shall include details of the extent of the installation& limitations of the inspection & testing covered by the Report . together with records of inspection, theresults of testing and a recommendation for the interval until the , next periodic-inspection .
P/196 . 634.1. Following the periodic-inspection& testing described in Chapter -62.
An Electrical-installation-condition-report,together with schedules of inspection& schedules of test-results, shall be given by the person carrying out theinspection, or a person authorized to act on their behalf, to the personordering the inspection. Etc . refer to.
P/196. 634.2. Any damage, deterioration, defects,dangerous-conditions and non-compliance with the requirements of theregulations, which may give rise to danger, together with any significant-limitations of theinspection and testing, including their reasons, shall be recorded .
2392-10 : Circuit-breaker(s) - circuit-protection .
Tripping-characteristics & therefore circuit-protection are set by the installer.
2392-10 . Installing : Overcurrent-protective-device(s)
Fault-protection .P/53.
411.3.2.2. Overcurrent-protection-device , providingcircuits Not exceeding 32A . Shall havea disconnection-time not exceeding , 0.4s . Table 41.1
Reactions: 1 person
2392-10 : basics .
Testing for Continuityof protective-conductor(s) 612.2.1.
to ensure that thecircuit-protective-conductors, ( CPCs ) is correctly connected, as the Regulation specifies . when testinghas a total-résistance which is low-enoughto permit the overcurrent-protective-device to operate . with the disconnection time requirements of Regulation - 411.4.5.
Earth-fault occur . RCDs for additional-protection
Reactions: 1 person
Re-take - Useful Information for 2394 :
Electrical Course Trainees Only
Thread Tags
amberleaf,
Richard Burns,
