Discuss Re using Bakelite switches in the UK Electrical Forum area at ElectriciansForums.net
Evening All
Just quoting for a re-wire and the customer has asked if he can keep his original bakelite switches, not sure about this but guessing he can't as they don't conform to current BSEN. Can anyone point me the right direction??
Cheers in advance
Evening All
Cheers in advance
Might find some difficulty in sourcing the wooden blocks for these switches Dave. Assuming they are installed on a wooden block.
do you need a tool to access the live parts inside? a pic.would help.
I refitted two on a rewire for a young couple around 3 weeks ago, Crabtree with the wooden pattress, just parked the cpc in the hollow behind the pattress with a 2 port Ideal connector on it, fiddly things those. View attachment 48559
Hi Dave - I've made a fair few of these pattresses out using oak and a router. Originally, small holes were drilled immediately behind the terminal for a single core to pass through - is that how you did it? I always worry about the proximity to the terminal, but tend to drill a slightly larger hole. Just wondering if you had a better approach! (I've also considered spraying with some-kind of flame retardant).
(Apologies if this is considered 'post hijacking'. I've read the rules but assume this is ok. Lurked here for many years, not commented much but this sparked my interest!)
I actually reused the original pattresses, yes small holes were drilled through lining up with the switch terminals, the cores have to be pretty accurate on the length as you can't really ease slack back in behind, I've probably binned well over a hundred of these switches over the years, kind of wish I'd kept them now. :)
reminds me of my dad's house, built 1926, purchased in 1958. bakelite switches, VIR cables, asbestos backed fuses in wooden CU., all original installation from 1926. 15A round pin sockets, no fused plugs, house never burnt down. nobody got electrocuted; had to rewire socket circuits 1980 due to them new-fangled 1363 plugs on all new appliances. only fuse that ever blew was the DNO 30A rewireable. it popped soon after we swapped the coal fired cooker for an electric monstrosity. (1988). welling up now.i loved that cooker fed from the adjacent coal fire, until the cat decided to sleep in the oven and mother fired it up for sunday dinner. never seen a cat run so fast with it's fur smouldering.
You are both from Leeds....... is there a plush area? ;o))))
Makes me feel old, mine was built in 1906.....
Reply to Re using Bakelite switches in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Evening all, Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going...
Hey - I had a workman come round this morning and he had to detatch the light switches. Afterwards, he put them back on again, but something seems...
