J
jay b
I know prob been covered lots of times but can't find on hear and can't find relevant section in BGB, shower isolation switch can this be in a separate cupboard ? I am sure a distance factor applies but I can't find it brain gone for walkies can anyone advise or point me to wright direction in BGB ? Pls thanks all
Having an isolator in an adjacent room/cupboard is preferable to not having one.
:smilewinkgrin:
Thanks guys the switch is in a cupboard (airing) of the hallway just checking distance and visual aspects but could not find relevant section in BGB so thanks guys thought it was ok but something was telling me to check on it
I would of thought if isolation switch has to be sited outside the bathroom ie hallway / landing, then switch sited near bathroom doorway would be far better, so as to easily seen if any problem occurs.
You always do it this way that I came across lol
I assume there was a switch there before and someone changed it to a pull cord, and yes it is above the bath op end to shower
The last wet room I done, the shower isolation pullcoard was about 300mm to the left of the shower, suffice to say, I moved it over near to the light switch.
It's much better to be sited outside of the bathroom so you can switch it off if wife or kids are spending too long in it ............. ;)
