hi everyone. new to the forum and have a question i would like some guidance with please.
i am wanting to switch between 2 ipod docking stations on my multiroom audio system.
i have a relay and base 230vac/30vdc.
i have managed to wire it so it switches manually how i want it to by pushing the button on the relay. so if i push the button ipod 1 comes on and when i release the button ipod 2 comes on. so far so good. i figured that i could use a d.p switch with a feed in from a power supply then a feed out to energise the coil. job done.
problem is i dont know what voltage i should provide to energise the coil as im only switching rca audio which is basically volt free.
can i provide 230v to energise the coil?
you finished it yet?
7400 Quad Nand set up as an SR Flip-Flop with a low noise Opto-Isolator,tactile button switch (if you want to do a very basic switch circuit for just the audio signal) what are you doing this for ?
Good idea, basic latching switch...press once for on press again for off (or change over)
be a good project for this lad
