Discuss Reliability of LPG Honda Suitcase Inverter Generators in the UK Electrical Forum area at ElectriciansForums.net
marconi
Mentor
I have been working on an off grid application using PV panels and an inverter-charger-battery to power small mobile installations. The client understood that because of the available space, the area devoted to PV panels and volume available for battery would mean that in Autumn - Winter, the installation would not meet the the load profile so the original LPG generator would have to be run to provide some or all of the power. It has been a success Spring-Summer when the generator has not been run making a £100 a week saving in LPG per installation of which there are 20.
The generators are 3.4KVA induction alternator types with a Honda engine converted to run on LPG. Before PV, they ran 12 hours a day, every day of the year. Because of the maintenance requirement, 90% of the time the engine repair or replacement, the client has learned how to do this for himself and successfully.
The problem with these generators is that the voltage regulation and frequency control are crude and not well suited to connection to the inverter-charger. The load profile is such that for much of the time they are lightly loaded (75W) until a freezer, 2 fridges or a drinks chiller start up.
I have argued that the client should swap to LPG Honda inverter generators - better V regulation and f control, and higher fuel economy because they run up and down depending on the load.
My problem is I have no real-life information on how they perform in terms of reliability if used for long periods (12 hours) every day as would be the case in Autumn - Winter.
And can the engine be repaired/maintained 'easily' in-house?
Do you?
I have seen many a market stall or burger van using them. By the outside case marks and damage, they seem to last quite some time. Most burger vans have a light and a boiler attached so loading is below 100w most of the time but 1kw or more when the heating element kicks in. 8 to 10 hours a day seems normal for them.
[automerge]1571123686[/automerge]
Also, you can run more than 1 in parallel, there is an optional sync. Cable if I remember right. Gives the option of pulling one out for service with no down time.
Reply to Reliability of LPG Honda Suitcase Inverter Generators in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
I know it's not neat, but can I simply run a single extension cable from a small (3KVA) petrol, portable, inverter generator, positioned outside...
