A
Adam W
I was leafing through the 'Kleeneze' catalogue and found this:
What are everyone's thoughts on repairing cables with self amalgamating tape, and should Kleeneze really be suggesting it is OK to do?
It's a good way to repair a cable sheath. And is also good for insulating lugs and busbar, but the uneducated public may think its ok to use it where a cable has dammaged inner cores, that would cause heat and consequent burning.
I have a couple of rolls in the van, though I didn't pay that much for them.
PRO POWER|SH5007SAT|TAPE SELF AMALGAMATING | CPC
I use it mainly for a watertight seal on sat dish LNB connections. I also used to use it when I was in the motor trade as a temporary fix for punctured coolant hoses, but that version also came with a fabric reinforcing tape to put over the top (Fix-a-leak Tape).
I'm not saying self-amalgamating tape should be outlawed because it can be really useful in certain situations such as around adaptaflex or in ELV situations, but when I'm doing PAT testing and I come across an appliance with a frayed flex I cut the flex back to the good part and re-make the plugtop, or replace the entire flex, so it appears 'as new', and maintains the integrity (or 'strength and capability') of new cable as designed by the manufacturer.
Wrapping a bit of tape around a cable, even the outer sheath, just seems a bit of a bodge IMO.
I think it's better not to sell the public the idea that taping up a joint is an acceptable repair, just as nobody is saying that repairing a cable with sellotape is acceptable.
Those socket cover things which leave the shutters open are more dangerous than not using them, but they are sold as making them safer so people buy them. If nobody sold them I doubt people would start sellotaping up their sockets to stop the electric leaking out.
Some would
used it on crimped cables instead of heatshrink before
Would you consider that an acceptable repair on an appliance flex as the picture in the catalogue is suggesting?
What if you were PAT testing an appliance and the lead was held together with tape/heatshrink? Pass or fail?
For PAT testing I would always remove to see the cable below, 9/10 times would cut back and re terminate/flex the item. If the cores were undamaged, then Id make good with heat shrink and note this in the repair register.....
MAGIC WELD TAPE...!!! hahahahaha never head it called that before!! need to get some and place next to my magic wand in the van..!
