Discuss replacing consumer unit in the Australia area at ElectriciansForums.net
J
Justinsane
Hi, I'm replacing a consumer unit on an installation which has economy seven storage heaters. The fuse board for them is an old cartridge fuse wylex which is fed from tails split out of henleys. I think it was the original box which got left in when the "new one" was put in during the 80's. Its a TT installation with no RCD.
I have never wired up economy 7 before, do i need to replace both boxes or can i just replace with one?
Any advice would be greatly appreciated.....
cheers,
Justin
Some manufacturers make a 'dual tariff' board which allows peak circuits and off peak circuits to share the same enclosure.
They are configured one above the other, so if space is a premium then it may not fit.
Not sure how expensive they are tho.
Reply to replacing consumer unit in the Australia area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
HI My flat just failed the EICR because there is no RCD in the consumer unit. There is no space for a new RCD as the consumer unit is full. Do I...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
