C
CenterSparks
Hi,
I have just first fixed a rewire, going in to second fix and fit the CU soon. The old set up is a mess, Currently running of 3 meters?! Into 3 different fuse boards. The electricity board are coming in a few weeks to move one of the meters and I presume scrap the others (Customer has told me). Is it acceptable for me to just leave my new tails connected into the new CU ready for them to connect when they move the meter? Am I right in thinking they will put the tails in for me even if i'm not there? I don't wan't to put the tails in the meter that's staying now myself if there coming anyway. I don't wan't to pull the fuse either as it's from the 50's and looks like it wold fall apart in my hands. Thanks for any help.
In theory as long as your tails are ling enough and correctly identified they should connect them, mind you the DNO are law unto themselves.
I've had them refuse connection of an elderly lady who had no heat in the middle of winter just because the neutral tail was not marked blue. Idiot packed up his tools and got back into his van and said a re-appointment was needed when the colouring was correct!!
ling or bling...
didn`t realise they were using gold tails now....
Hi,
how long are the tails?
Some DNO's will want the dead test results before connecting up, so I would leave a copy if you haven't already done so.
Which equates to a scribble of made up figures coz the majority of them don't know what the figures represent in the first place!!
Be that as it may lol, I wouldn't give them any excuse not to connect, some also require the spark to be present, as another poster said, "a law unto themselves"
oh it's well known that they carry a book of excuses which is regularly opened when connection time approaches. The spark is usually needed to show them how to connect the tails for them.
Nowadays you'd be lucky to have an engineer you could actually converse with.
Hi all,
Thanks for the replies.
The meter is being moved next to the CU, It's currently only maybe 2 meters away as it is. Don't ask me why it's being moved. Should I just leave the tails at 2m? or something for them? Will they really not connect them if I'm not there? If I put an isolator in with my tails connected or even my tails not connected will they defiantly connect up to that point?
Hi all,
Well.... you need to have a copy of the EIC with dead tests, a nice new shiny 100A isolator with your tails in and most of all why can't you be there? Best to try to be....
