J.C.E
quoting for my 2nd rewire- 1st one was profitable- but I still think I went in bit too low
this one i am thinking seems too high now!- what you guys think on a quick glance...
[TABLE="width: 500"]
[TR]
[TD="bgcolor: #bec0bf"] Description
[/TD]
[/TR]
[TR]
[TD] Under stairs
New Dual RCD 15way consumer unit (3rd amendment compliant)
Install main bonding to gas meter and main water stop-cock
[/TD]
[/TR]
[TR]
[TD] Kitchen
1x Cooker circuit+ local isolation switch
1x under worktop single socket for hob+ local isolation switch
1x high level single socket for extractor hood+ local isolation switch (exc hood)
1x under worktop single socket for w.machine+ local isolation switch
1x under worktop single socket for d.washer+ local isolation switch
1x single socket for fridge
5x above worktop double sockets
6x down-lights- fire-rated LED’s[/TD]
[/TR]
[TR]
[TD] Conservatory
2x wall lights+1x light switch (light fittings to be supplied by customer)
2x double sockets[/TD]
[/TR]
[TR]
[TD] Outside Toilet
1x pendant light+switch
1x spur for boiler (supply to boiler only)[/TD]
[/TR]
[TR]
[TD] Dining Room
4x down-lights- fire-rated LED’s + dimmer switch
1x centre light (light fitting to be supplied by customer)+ dimmer switch
3x double sockets[/TD]
[/TR]
[TR]
[TD] Living Room
[/TR]
[TR]
[TD] Downstairs Hall
4x down-lights- fire-rated LED’s+ 2way switch with upstairs landing
1x double socket
1x mains power smoke alarm[/TD]
[/TR]
[TR]
[TD] Porch
1x ceiling light+switch to be inside hall (light fitting to be supplied by customer)[/TD]
[/TR]
[TR]
[TD] Upstairs Landing
5x down-lights- fire-rated LED’s+ 2way switch with downstairs hall
1x double socket
[/TR]
[TR]
[TD] Small Bedroom
1x centre pendant light
[/TR]
[TR]
[TD] Middle Bedroom
[/TR]
[TR]
[TD] Front Bedroom
4x double sockets[/TD]
[/TR]
[TR]
[TD] Bathroom/toilet
7x down-lights- fire-rated/bathroom rated LED’s+ switch outside
1x supply for shaver point (unit to be supplied by customer)
1x wall fan with humidistat sensor[/TD]
[/TR]
[TR]
[TD] Shower Room
1x down-light- fire-rated/bathroom rated LED’s+ switch outside[/TD]
[/TR]
[TR]
[TD] Loft
1x batten holder light
1x single socket
10mm cable from consumer unit under stairs for future electric shower[/TD]
[/TR]
[TR]
[TD] Outside Garage (via 15/20m 4mm swa)
2x double sockets
1x batten holder light+switch
2x security lights
[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
getting around £4500- and then I still need to charge doing the virgin media bits on top of this
whats your thoughts
In summary do you have the qty of sockets, lights & switches, dedicated circuits?
Are the switches and sockets white or metal?
quote based on everything being white plastic and white down-lights
32x sockets
44x lights (majority led downlights)
1x fan
cooker circuit
2x smokes
boiler circuit
1x shower circuit only (future)
15m 4mm swa supply out to shed (points inc in count above)
you're definitely not too high on price. if anything your 4500 is on the low side. first impression from your spec, to me, is about ££5500
32x sockets
1x fan
cooker circuit
2x smokes
boiler circuit
plus 2 fuseboard presumably?
i would say your about a grand under priced. it also depends where in the country you are.
and it will affect the time taken if the house is occupied/cluttered/kids in your face.
armored to be clipped
only 1 15w c/u in house- not one in garage
house is completed empty (just been bought)- and they wont be moving in until complete
I think you'll do alright at £4500. Are the down lights cans and led lamps or integrated fittings?
cans
i dont understand the pros of using integrated? more expensive and have to replace the whole thing if it fails
The general idea is that with integrated you are getting a higher quality purpose designed product as opposed to a retro fit solution jammed into a receptacle not specifically designed for the job. Integrated are designed to dissipate heat more effectively and therefore prolonging the LED life and reducing the risk of failure. This is the reason many integrated units offer long warranties.
cans
Led replacement lamps: modern technology which requires efficient cooling squeezed into old shapes designed for lamps which need to be hot to operate correctly and then put into tin cans which trap the heat in.
Integrated LED fittings: modern technology in a fitting custom designed to make the best use of the technology giving the best efficiency and lifespan.
