J
Jimmyb
I’ve been asked by a family member who has just had some new wiring in his house if I could look over the job as they didn’t get why they had to have 2 rcd's now, I told them about the new regs but for their piece of mind I said ill pop over some time and have a look, everything look spot on apart from one thing the old downstairs ring being on a 20amp mcb when I look at test sheets it was tested as ring and all results was good so I decided to check it myself, all results the same as on sheet, so I thought ill ring him and ask,
the reply I got was the cable ref method was 102 due to the wiring being dropped down from upper floor and into the wall. I asked why not use 4mm then but he said it hard getting 2 x 4mm cables into the sockets
so my question is are 2.5mm rings with ref method 102 ok on 20mcb, I’ve only been in the trade for 2 years so wondered what you guys thought
