Discuss rocker switches bargain in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
I’ve had that happen a few times when stuff comes off eBay from China.....of course I always return the surplus items back to the seller..........:rolleyes:not!
client ofmine is a pub. he's got these carvery warmers. every month one or 2 go down. either burnt out switches or spade terminals fried. sometimes the connector block where the feed cable connects. can't understand why they fail so often. only a 2.2kW element.
Where heating elements are involved, the switch is often the weakest link......at least he’s now got plenty spares!
nope.i've got the spares. he pays a min of £40 + 1 pint of Old Peculier for as visit. he makes on the food. i make on the call-out.
the chinese ones, funnily enough, seem to be of better quality that the ones i got from wholesalers. maybe those were made in north korea by dogs before they were eaten.
Yes they need good quality switches over there.....maybe there same type they use to launch ballistic missiles?
cheap crap will do. only needs to work once.
Reply to rocker switches bargain in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently purchased this extension lead (not sure if im allowed to post links or not, apologies if not allowed): Masterplug Surge Protected...
I purchased a couple of these which arrived today https://www.ebay.co.uk/itm/New-220V...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649 The belts...
Hello all.. Just wanted to let you know about a bargain! I wouldn't usually buy from e-bay, but you cant really go wrong with a metal back box...
Hello forum. I am new here and seeking some expert advice. I am trying to make some DIY led light strips that will be controlled via DMX. The...
Hello all, hope this is posted in the right place. You'll probably guess after reading this post for help that i'm not an electrician! I've built...
