M
megaman83
hello sparks i was just wondering if any of you know of a two wayed rocker switch! you know the ones that rest in the middle ( 0 position ) , press up and hold to open say, and press down and hold to close, and it will automatically spring back to the off position, could be used to open and close a motorised valve etc! i have never seen one of these that could be two wayed! many thanks in advance
Come across them in electronics etc, but not aware of them for fitting in a normal Electrical Installation, I assume you are trying to source something for a normal switchbox a bit like the push to release type thing for security doors etc.
Cheers.......Howard
MK do a 2 position and off switch in grid plus, but it's not a push to make style, i.e when you switch it, it stays switched. I use them on PIR floods in some jobs i.e sensor mode, off and permanantly on.
hi mate, where would you get one of these 2 position switches? i cant find it online and the wholesaler near my house didnt have a clue wat i was on about. if you could post a link for them id be most grateful. thanks
MK Grid K4899WHI
MK Grid Switch 2 Way & Centre Off SP 20 amp
MK Grid Range Overview
MK Grid Plus is a modular switching system including switches, indicators, dimmers, secret key switches, printed 20amp double switches and buzzer units, making it the ideal system for commercial, public and residential buildings alike. Without any requirement for special tools, Mk Grid modules are extremely easy to fit and change, simply clipping into the mounting frame.
10 Amp Retractive SwitchMK K4900 WHI
10 Amp Retractive Switch​
10 Amp Momentary Switch Module
( 2 position - Centre Off Retractive Push Switch)
MK
British Made - 10 Year Guarantee
New Logic Plus Design.
MK K4900
I think this is exactly to your requirements Megaman.
Trypod has posted the part number of the ones I described earlier.
megaman83,
Guest123,
