Down lighters , wot I recently done was had a choc box's bank of 4 down lighters off each choc box 6 cables in box( it was above one spot so was accessible ) and single cable at each downlight , I must say It worked really well , 2nd fix was a absolute doddle . 1st time I tried it out it will now be my standard installation method with some sort of master joint box . Note also I recently come across led fitting downlighters jcc I think with 3pole blue click plug things .... Really good idea ! About time , previouse installation method mentioned wouldn't be needed to much as connecting of anything with up to 3 t+e would be easily done ( but a bit pricy at the mo )
