B
Big n Daft
Right ho chaps and chapesses,
Its time rat out the rubbish. What have you used recently that has been complete and utter poo.
Lets start with anything that has Proteus on the label, and there is some completely useless swa cable out there as well. You know the stuff, its like a coiled spring sitting on the drum waiting to snare you at first pull.
Reactions: 1 person
Hit a bit of a rich seam with this one.
Next one is conduit boxes with a p!ssed thread, so you give the pipe a tweek and either the spout cracks or the pipe collapses snapping in two.
NEXT........................
Reactions: 2 people
Magnetic cable guide Magna Mole cheaply made plastic tool, suitable for the DIY market but aimed at professional electricians. Anything tougher than plaster board walls and plastic splits or disintegrates spilling the magnets the tool relies on to work. Utter crap!
Reactions: 1 person
cheap and nasty cable rods that splinter and leave nasty fibreglass down the finger nails and under the skin.
cheap naff screws
socket sinkers :) what a load of old tosh
100+ not so fast fix boxes i got stitched up with in Jarrow
a well known large electrical wholesaler that ripped me for £13.50 for a box of penny washers that were £3 in tool station
those 10 lengths of plastic conduit i got stuck with the other week, cracked and split, tbh I thought it was me out of practice but by the previous posts maybe its just naff cheap plastic they are using now.
the rather expensive allegedly dimmable low energy lamp that did not dim
Reactions: 1 person
Tamlight....often poorly thought out and thrown together....Gotta say,despite the slagging off of proteus here,I use it on cheap jobs/temp site supplies etc and have never had a problem with it.
Niglon,stopped using their stuff years ago,after SWA glands which either wouldnt start or pulled off even when wound right down...and 2" locknuts which were so flimsy and loose you could tighten them by hand and they would strip.
RPP IP sockets.....Oh dear.
Marshall tuflex minitrunking....where do you start?
BELL linear T/H lamps...no end of hassle,contacts set too far back in the endcap so they wont meet the pins on the fitting.
Could be here all day!
cheap glands, BW glands of any make (i always use CW or E1W), a manufacturer called MCS make our MCC's and control panels, and they are rubbsih in some respects ie- p[anel; trunking that sits dirctly on the gland plate, so that i cant remove it to install cables.
AS said previously
Cheap surface patress' that shatter as soon as you try and open up for a cable
Control gear brand ccu's and breakers......chap tat!
adaptable boxes that have pre determined holes with not enough clearance to get a lock nut on
MK accessories that dont grip the conductor well enough (i only have this problem with MK)
cheap swa with inner insulation that wont strip
ill stop ranting now lol! thank god for the likes of hager, spax etc etc!
AS said previously
and adaptable boxes with dual concentric knockouts ( 20mm and 25mm ) when you try and knockout the 20mm, the whole 25mm comes out.
Reactions: 3 people
Was that another great idea from Dragons Den, just like the horrible choc block box piece of tat.
I definitely go along with that one and also the cheap screws supplied with fittings that strip as soon as you look at them.
Cheap cable that is stuck together so you can't strip it.
All patresses that shatter and those that do not have enough break out to fit a 2.5 T&E
Reactions: 1 person
RPP sockets and switches, the whole range, pants
I wonder between us all how many man hours have been wasted rectifying c9ap gear. And when you go to the wholesaler they tell you- "you are the only one that brings stuff back".
So it's not just us then!
Just as a matter of curiosity, does anyone else have problems tightening the screws on 16A Crabtree Polestar breakers, or is it just me? All other sizes appear ok, just not the 16A once.
Can't comment on Crabtree specifically, but one recent-ish thing which is really getting on my ---- is that we are now all encouraged / required by the various CU manufacturers to go out and buy expensive torque screwdrivers.....and then they fit cheapy cheap screws inside that shear before you get anywhere near the setting they say to tighten too - neutral and earth bars normally. FFS, really.
Reactions: 2 people
And to add to the list of crap kit: Any light fitting, ever, that has come out of a box with 'Homebase' written on it.
Reactions: 1 person
This crappy bathroom lightfitting that a client insisted we put up for her the other day B&Q with "made in china" on the inside...pressed out of tin so thin you risked buckling it just by holding it too tightly...cable entries in the wrong place and crappy plastic clips holding a glass shade to it all....just dying to come off and conk someone on the head that one......if it were my choice it would have been in the bin with it..........
Any plasterboard backboxes from TLC! They're horrendous.
Reactions: 1 person
This product was featured on Dragon's Den when it first came out and I seem to remember the quote "You kind of almost want your product to break occasionally" when addressing the size of the market. Guess this is why they sell spare magnets ;)
Rubbish products/materials
Australia
Thread Tags
Big n Daft,
ipf,
