E
Elliot Knight
Hello,
I am adding sockets to a garage conversion. The ceiling is already plastered, and above the ceiling is a bedroom. Between the ceiling and the bedroom, the void is stuffed full of insulation. Looking to avoid cutting large holes in the ceiling or above floor to remove the insulation and run cable (if I fish the cable leaving insulation in it would need to be derated), would the following be suitable.
Run the cable up the wall vertically from the socket to the 150 mm safe zone below the ceiling. Go across the safe zone horizontally till in line to the next socket. Come vertically back down the wall to the socket. See illustration, red line showing proposed run.
As the walls are not yet plastered, this would be a fairly easy run to achieve.
. don't forget that you can run horizontally direct between sockets.
