The only place I use knock on clips are out of sight and out of reach, if anythings clipped visible I use P clips much neater if you know what you're doing, and to drill a hole to put a plug in so you can nail a tower clip into it is ridiculous I literally can't believe what I'm reading
P clips on T/E will look naff, cant see any reason why a drilled hole for a plug/tower clip is ridiculous.
And who says I use P clips on twin and sling... think about what I said, and I didn't know twin and earth was the only cable ever created...
In the same place you might use P clips.
Why don't you come over my house and try and find one piece of twin and earth clipped to brickwork, and for each piece of cable you find I will give you a £1000....the only tower clips in my house are on the twin and earth on the joists, the only cables clipped visible in my house is the 16mm earth P clipped in my utility room to the water main, and soon to be a small piece of FP between the two outside lights in my back garden which I will be using P clips, so like I said name one place in your house for example where you have visibly clipped a flat t&e to brickwork...
On brick wall in loft. With occasional pin plugs where necessary. Also used for a small section with round clips for g/y feeding rod in garden. Also used with a run of NYY on rock hard render. Personally I don't like how p clips look whatsoever. Each to their own eh....
Wot I've done to combat this issue before on a led floodlight in garden only needed 3 clips per say .
Level line
2mm masonry drill bit
Snip bits of 1.5mm singles ( used as a wall plug )
Nail in clips
Bob's you're mothers brother
Prior to this thread I'd never heard of "pin plugs" if I saw them I'd pick them up
My solution worked a treat mind got me out of trouble that day
You might get away with hammering masorary nails into brick, but try doing it in granite or concrete blocks made of granite! Then the nails bend like they are made of lead, and pin plugs come in useful.
Never come across these before
Just ordered a few boxes for the van!
One more annoying problem solved on my quest to perfecting my installation practice
Clipping coax cables to the external render or brickwork of a house has always been a pain for me, not any more!
thanks for the heads up :)
got mine from ebay, plenty on there!
To the OP,
BQ used to sell branded versions but they now have their own unbranded version. Looks exactly the same product as the other I have. So maybe they won't be disappearing afterall. I know my stocks will now last a good while!
