Discuss Schneider power logic 5100 in the Commercial Electrical Advice area at ElectriciansForums.net
Hi
I’ve been asked to retro fit one of these units, it’s not something I’ve done much of and the only one I’ve done is a Eaton which came as a kit whereas this would be fitting it into an existing board.
Is it possible to retro fit or does it need to be fitted as a kit?
The eaton one was essentially connecting fly leads to the main switch tails which I presume is the same?
Appreciate any input
You can retro- fit for sure. Recently installed an ABB one, very good. House it in its own enclosure. It was power off for the CTs though and voltage connections, as these tend to be installed at the MDB its trying to find a good time to do it
Reply to Schneider power logic 5100 in the Commercial Electrical Advice area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
