He's got 3'' threaded fixing screws, though.Fit red plug in back box and use a 2 inch 6 screw . Just make sure you don't snag any cables.
Ok missed that not sure you can get 4inch 6s . Now I like Strima's solution.He's got 3'' fixing screws, though.
Is the adjustable lug? You could swap it out with a good one.
otherwise you could maybe twist or bend the lug through the middle to close the hole up a bit??
Drill out and re thread to 4mm mate. Easier than replacing a box.
BackBox Savers
