Search the forum,
Discuss SELV/Control wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I was wondering if voltage drop applies to SELV etc voltages, situation in question like 24V AC & DC for control etc?
Surely not?
Along the same lines if 230V is used for control for example:
230V coming back from a panel and indicating when a item of equipment is running and indication lamps being lit in a control room or alike?
Does this come under voltage drop regulations?
Cheers
Surely not?
Cheers
I'll give you a clue...IT'S CALLED VOLT DROP​, it is not not 230V drop!!
I can't remember where I saw it, but someone on here has a sig
"once you have enough knowledge to satisfy the old boys you're too old and knackered to use it"
In my opinion there is no such thing as a stupid question, just a stupid answer :)
As an apprentice I got used to hearing.."what the .... do they teach you at college!!!"
If you start your questions with I'm an apprentice you might get a bit more slack :)
I used to have an escort rally car and needed really bright lights. When i measured the volts at the lamps i was getting 10.8 instead of 13V. I re-wired the lighting taking a feed directly off the alternator, through relays and re-wired direct ground cables to the chassis, all in the name of reducing volt drop and that was only 12V DC, so yes i matters alot.
cheers
Thank you I'll just put my sig as Apprentice haha.
I was just thinking with with 24V DC you couldn't really apply volt drop (obviously you could but it's slightly different) as it's not really like mains voltage and is a part of a control circuit for starting a pump or on emergency stop. Struggling for words here really.
Put it this way 24v on a 100mt cable run controlling a relay or control valve I think you'd have to consider volt drop
Think I worded this wrong from the start. My understanding WASNT that some how magically 24V or selv was immune to voltage drop. I just meant would the selv/control part of an installation fail the electrical installation certificate? Even if the control part was over the allowed values, just made me think that I was at work we fault finding a motor starter, and the 24V coil was still pulling in at around 19V.
Cheers for the replies though guys :)
Reply to SELV/Control wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Buzzer wiring to ACROPRINT FT217 Time Clock - see drawings below Question: I would like to hookup 7 Buzzers to be driven off from the above...
