Discuss Shelley2 dimmer with 4-way in the DIY Electrical Advice area at ElectriciansForums.net
Hi there,
This is my first post as I am new member here. I would really appreciate if anyone can recommend wiring a smart switch called Shelley2 dimmer into an existing circuit that I have here at my house with three switches controlling same set of lights, two of which are 3-way and the third one is 4way. I thought the 4way is the last one in sequence so it is the light source but now I am not sure about that. Also there is no neutral in the box. Any questions or recommendations will be really appreciated. Here is the link for shelly2 wiring with and w/o neutral: Google Image Result for https://hometechhacker.com/wp-content/uploads/2020/12/ShellyWiringOptions.png - https://images.app.goo.gl/ZyPXGmgTGgHp1RKu5
Reply to Shelley2 dimmer with 4-way in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, This is my first post as I am new member here. I would really appreciate if anyone can recommend wiring a smart switch called Shelley2...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
