• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss Should a giant steel framed human aquarium be earth bonded? in the Electrical Forum area at ElectriciansForums.net
Deuce
Regular EF Member
I have a large, portable steel framed tank. approx 6m x 2m x 2m. It is used for actors/models to perform in for a variety of productions.
For many years now, I have had conflicting advice about whether or not it should be earth bonded. The initial response is "it's a giant steel structure, bond it!!". But then invariably someone else comes along and points out that, should the tank itself become energised, the people in the water within the tank would become part of the return to earth - the current would flow through the tank and them. If it was not bonded, as it is by design insulated, they would be ok. At least until they tried to leave the tank.
To date our solution has been to be super cautious of anything that could even present the possibility of bringing current to the tank itself. But how do we make a once and for all decision on whether it should be bonded without any professional consensus of opinion?
Leesparkykent
Super Moderator
Staff member
Super Moderator
It would be site specific.
Deuce
Regular EF Member
Earthing and bonding as far as I’m aware as 2 separate things
Maybe I'm wrong in my terminology. I thought bonding was the connection of two conductive systems, and in this case bonding the tank to earth = earth bonding. Feel free to educate me though - that's why I'm here asking :)
Deuce
Regular EF Member
Can you give me an example of a site where bonding the tank would not put those inside at risk if it were to become live?
We take site specific factors into account for a variety of reasons but I can't see how the tank being earthed would ever be a good thing for the people in the tank.
Marvo
Admin and gender confused
Staff member
Admin
Is Rcp ≥ (Uo/Ib)? What earthing arrangement does the electrical installation have?
Deuce
Regular EF Member
For clarity; my concern is that because the tank is full of water, it is the equivalent of forming a conductive shell around the occupants, and then passing current through it. It's not the same as earthing a fridge so that if the outer skin becomes live, anyone touching it doesn't carry the current. It's the equivalent of making them part of the earthed item itself.
Deuce
Regular EF Member
Varies! Our own kit (the filtration system) is bunded in case of leaks and all electrical fully isolated from the water passing through it. The environment alters as the tank is used at various studios and venues around the world.
Marvo
Staff member
Admin
So the whole tank and its associated equipment is effectively portable? It plugs in? It's also used in a variety of building structures ie some will have metal building elements in reach of the tank others won't........ Lol, You might have mentioned this in the OP
PEG
Respected Member
Is this fixed or mobile? I would be tempted to do a risk assessment where it is filled,and keep all cable connections away from it. Well away.
In my opinion,depending on where it is sited,the least number of possible electrical connections to it - the better.
markythesparky
Electrician's Arms
What is the tank sitting on/ in?
In the case of swimming pools, they are in or on the ground (earth). The idea behind pool bonding is that everything touchable is brought to the same potential and therefore minimises shock risk. TN-C-S earthing systems are not allowed due to the risk of a disconnected neutral and the consequence of mains potential within the pool area.
My view would be to TT it and have anything near it on a 30mA RCD.
Deuce
Regular EF Member
The one constant is that wherever the tank goes, 30ma RCD is the standard.
The tank is always sat upon a butyl membrane, so it's isolated.
If it was TT'd, of course that is a sound path to discharge current. But if the clamp is at the base of the tank, and a live lamp collapses and hits the top of the tank, the current would flow down through the tank and the water and through the people inside it surely. In that scenario wouldn't it be better that it was left isolated?
Marvo
Staff member
Admin
So there's 230v lighting within zone 1? This just gets better....
Did the tank and its associated equipment come as a certified design or is it just something that was fabricated and that's evolved and been added to?
Reactions: DPG
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
