Cheers mdj,
I am sure your right, some folk on here did recommend using a clamp meter and even if I did , I would have to put another fuse in to test It , and what would be the range of acceptable current to expect.
Kind regards
Snowpiece
Cheers mdj,
Kind regards
Snowpiece
Work that one out from the shower rating.
Hi Telectrix
I take it you mean it should be pulling between 33 and 35 depending on it being either 7.5 and 8kw.
I have looked up and seen that a 30amp cartridge fuse should be able to handle 40amp for at least in one hour before blowing so that in itself would tell me high current is flowing for it to blowing in ten minutes say.
Out of interest where would you recommend putting the clamp meter to measure current flow, in the CU where you can access the line or neutral, ive never used one that why im asking.
Irrespective of the above I am just going to recommend replacing with same size new shower as
MDJ suggest adding higher rating of fuse might just be creating rather then solving problems.
Many thanks for you feedback
Snowpiece
Hi Telectrix
Snowpiece
kill power to all other finals....just leave the shower circuit on...then turn on the shower...
clamp the tail...(one or the other...not both)...and observe correct current flow in relation to the clamp (there should be an arrow on the clamp indicating direction of current flow)....
take reading....
Hi Telectrix
Snowpiece
Jed Clampit'll help ya baawy
Sounds to me like the element is about to go , heating elements can be odd things even when cracked can work, until they pop , with rcb protection a fault like this would trip the RCD , to clarify this i would recommend that the shower be isolated and an insulation test carried out across the element , and as Eng 54 has said consider a consumer unit upgrade
or at least a stand alone board for the new shower....as the manufacturers instructions will invariably require RCD....
Are you being serious here??
Doesn't matter if you haven't used a clamp meter before or not, you should bloody well know where and how to measure the current flow!! I take it you don't possess an earth leakage clamp then either... Sorry i just find this quite amazing!!
............. Sorry i just find this quite amazing!!
Don't rise to it Eng!
I see this stuff and think it's just hilarious. Might get rid of my TV.
Unless you're going to provide a step by step instruction from a complete novice up to, I don't know, 4th week Apprentice level, just give up!
Would you walk into a pub and ask somebody how to ask for a pint?
Don't laugh too loud, but i've done that a few times in countries where i don't speak the lingo!! ...lol!!
