Discuss shower rcd in the Australia area at ElectriciansForums.net
Hi all
Have been to see shower replace (old for new) consumer unit has dedicated 32a mcb for shower circuit using 6mm cable but no rcd. question is can i cut into the 6mm cable from consumer unit install a rcd and then carry on to shower still on 6mm also can only find shower rcds with 40a breakers do i need to change breaker to 32a
thanks
Rich
Hi lenny
yes checked the regs and cable can carry 34amps so no greater than 32a breaker in the cu ,also its a cu with 3036,s and they have plug in mcb,s so i understand no rcds can be pluged into board,i will go with mark the spark,
Reply to shower rcd in the Australia area at ElectriciansForums.net
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi guys. I was wondering what size cable and braker I'd need for an electric shower. Just out of intrest am I close in guessing as follows: The...
Shower circuit (40a mcb 10mm cable 8.5kw shower ) tripping after 5 mins RESET trips after 2 mins...changed shower /cable /isolator still tripping...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
