Hello,
I am installing an ensuite with just a shower and sink unit in it.
Can I have installed, LED downlighters using a wall-mounted dimmer switch?
(the switch will not be within touching distance of the sink or shower)
Best to put the wall mounted dimmer switch in the shower. Once the electricity in the switch builds up a tolerance to the water, all will be good.
Without that build up of tolerance, it could be dangerous.
Always put your electrical equipment IN the shower, not out.
If in doubt, consult the bojit & skarpor best practice guide.
There you (all) go again; why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change? :)
OK, do the proposed work but don't use the light.. Or the room for that matter! On a serious note put it outside the room!
Quiet in the cheap seats Oddball...
East Sussex
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
shower room and led downlighters
Lighting Forum
ppeetteerr,
Midwest,
