This must be more than just switching off the mcb in the fuse box. This is because when you switch the fan off at the pull cord,there is still a permanent live wire connected to the fan for the timer. Breaking into a high current carrying cable with a junction box introduces more potential problems.
Already knew answer from previous forums obviously if you put part p u r alian, as plenty of leckys have asked this question! & got answers not abuse
well, you only posted half the info. anyway. answers would have been guesswork. e.g. is the shower on a RCD along with half the house, or is it on it's own RCBO? are the lights, specifically the bathroom lights, on RCD? what cable feeds the shower, and by what reference method is it installed? what OCPD protects the shower cable? are you fitting CCTV for a bit of voyeurism? so many questions.
so may questions & no answers, no rcds cannot fit rcbo as old unit, has reset mcb's, hager c.u. so fitting shower unit, 10 cm2, 50amp mcb with isolation switch, my question was realise need rcd for fan, can i get round it without fitting new cu, thanks
And people are asking questions because of the lack of information you gave, hence you got no answers, if some one advised you on how to do it it would be dangerous as from your posts you obviously lack the knowledge to do this install, however simple it is.
10000 /230 = 43.47----
hager 40 amp or 50 amp
Right, you decide to inform us of your working out, but i still think your calculation of cable size is slightly out,
Best advice has already been given,
Please get an electrician in before some one gets hurt
sorry cant get used to keys 10mm2, may get away with 6 mm2 due to distance ,plonker! sorry guys its a bit late orr
no may involved....it either is...or isn`t (taking installation methods, ambient tempreture, and grouping factor into account).....
there is a case for characteristics of OPD as well....
c wat u mean! lots to consider, was going to fit fused connection unit, will that cover 17th as regards rcd protection, taking into account zones 1/2
Your dancing with life or death, if you dont know even the basics of safe isolation. Have you got a neon screwdriver?... :confused:
