Discuss Signing off sub mains in the UK Electrical Forum area at ElectriciansForums.net
Hi all I've been asked to install 10 new sub main for 10 flats, that all have existing circuits and fuse boards. They just want new sub mains because they are moving the location of the fuse room. The question is do I really have to create 10 EIC Certs I use Nic Eic and they are a bit long for the work I'm about to carry out. The flats have all been tested by a previous electrical contrcator who is no longer operating.
You will require one EIC for each flat/number of flats fed from a single source of supply. If say 3 flats are fed from one head then that will be one EIC with the 3 subs recorded in the schedule.
There's nothing quite as satisfying as 3 EIC's to do at the end of a hard days graft. It's what makes it all worthwhile. You go to bed with a warm glow knowing you'll be doing it all again tomorrow...:eek:
Reply to Signing off sub mains in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
