Discuss Sinks, electrics and blanking plates in the UK Electrical Forum area at ElectriciansForums.net
Quick question, I have a socket in the wrong position in a utility room, if I put in the sink where I want to, the sockets will be within 300mm of the sink which I know is a no no, I can do without the socket, could I fit a blanking plate over the wires (having joined them to keep the ring) and still be within the regs?
Thanks for any help
Down2earth
if it's a new board wqall, why did you not pull cables up and joint above ceiling with M/F box?
It's a new sloping roof with only minimal clearance in the void, now that it has been insulated and plastered I would not be able to get to the cables.
Regards
As said 300mm is a guidance not set in stone the regs refer to external influences also risk assessment is the in word now.
Reply to Sinks, electrics and blanking plates in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
My customer is having a wood burner installed. The stove installers have said he needs to get the 2 sockets that are directly behind the new...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
