Smoke /Carbon detectors | on ElectriciansForums
Discuss Smoke /Carbon detectors in the UK Electrical Forum area at ElectriciansForums.net
England
Hi guys,
Question for those that install smoke and carbon detectors.
This situation, mid terrace 2 storey 2 bed house.
Typically most houses have a smoke detector on the landing.
I was proposing installing:
1 x smoke on landing
Open Dining/Kitchen -1 x smoke dining room end.
1 x carbon kitchen end (near gas cooker)
However customer asked an interesting question about the gas boiler which is situated on the landing in an old airing cupboard.
Would it better to install a smoke and a carbon on the landing?
Is there a combination unit worth installing? Is that practical?
PS System hard wired
Be interesting to know at what height people are installing CO detectors? Had a fireman round to check my chimney the other day and he mentioned having CO detectors at pillow height in bedrooms. Must admit that logically you’d place them close to any source that poses a risk of incomplete combustion ie anything with a flame
At normal temperature Co is heavier than air so it gathers at low levels. As it leaves an appliance it is warm so it rises to ceiling height. A Detector on the ceiling close to any appliance is likely to detect it early. Further away from the source, as the gas cooled and dropped, a ceiling detector would have to wait for the room to fill up with Co. Hence in bedrooms pillow height is recommended as by the time the detector operated at ceiling height it would be unlikely to wake you as you would be dead.
Remember as a student in a bed sit in Manchester Mrs F A to be and I had a gas fire in our room. Cos it was very cold we taped a layer of polythene over the window. One evening Mrs F A to be started to throw up (not down to usual student excesses :rolleyes:). Ended up down A&E for a few hours with very disinterested medics. Couldn’t work out problem but then realised it was more than likely CO poisoning. Much prefer sleeping in a cold bedroom with window open even in winter.
Yes, you would need a whole different means of comms by then ... It's just new to me, in that I put them near to the appliance that could generate CO and so it's always detected early, in theory (?).
Reply to Smoke /Carbon detectors in the UK Electrical Forum area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
I've looked at the fire assessment from the last HMO I did for the same landlord and fire assessor, the risk assessment is pretty worthless, it's...
Go here: Guides and Publications - Aico - https://www.aico.co.uk/technical-support/guides-and-publications/ halfway down the page is a product...
And dont forget that the RCD will prob need upgrading to Type A
SO Aico do not give the supplier a credit for a returned unit etc etc ?? Are they now owned by Tescos (THose in the know will get it !)
