Discuss Smokes wired to a JB? in the UK Electrical Forum area at ElectriciansForums.net
Have a bit of an awkward run at a job and was debating whether it was easier to wire all the interlinked smokes to a Wago box or JB. They are Aiko smoke alarms and wanted to know whether anyone has done this before and would it make any difference?
I was on a rewire and wanted to branch off to provide cable for a future area. I had it in my mind that they had to go from one to the next but no, as Tel says as long as the interconnect is separate you could spider it if you wanted!
They have provided larger terminals for that reason.
Always liked Ei (Aico) detectors but size of terminals and wiring space was definitely an issue with them.
Perfectly acceptable IMHO as long as the wago box / JB are fully accessible
Terminal size has improved and I’ve seen smaller areas to make off your cables! ie - every downlight out there! They must have heard you thinking!
Quite common to see a branch (2 outgoing radials) coming off the same breaker. Nothing in the regs to say it's frowned upon.
Reply to Smokes wired to a JB? in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Hi all, Just wondering what the general situation is with other people on smaller jobs, do you give a quote or estimate to the client before you...
Hopefully an easy one without much debate but I've just had spoke to someone who has had an electrician go to his rental property and say it needs...
