Discuss So simple, so frustrating in the Electrical Tools and Products area at ElectriciansForums.net
these are same as my AVO 8leads. stuff G38. the don't fall off.
I can tell you that the Megger ones and the Kewtech ones do the same although mine are a little more audacious and will jump off whenever they feel like it, not just when I'm not looking at them :)
I use these to clip onto recalcitrant bus bars and clip on to the end with my test lead, nulled ofc. They are used for shorting between L and E etc. when doing R1/R2 usually but double as a solution to hard to clip on parts at the DB.
I bought some of those Kewtech clips, crocs, alli's or whatever. They seem to provide a highly increased resistance to the circuit on test, which fluctuates and no amount of filing can improve. Found them so unreliable, I binned 'em. Is yow's ok?
I've got a Kewtech wander lead and the croc clips have decided to self destruct on that more than once.
Wrap an elastic band around the jaws of the clip so that it pulls tighter and does not slip off so easily.
too sensible. :D:D:D.
however, here's a tip.if you want to ensure good IR readings on a circuit, use wooden clothes pegs instead.
they do clip very well to an apprentice's testicles when you want to take an IR reading though.
Reply to So simple, so frustrating in the Electrical Tools and Products area at ElectriciansForums.net
Bloody specific fitting megger test leads! I've lost 2 of my megger probes now. I have plenty of crocodile clips and the long, thin, bendy probe...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
Hey everyone, here's my imaginary problem, let's say I have 2 light bulbs, both of them take energy from the same source, however, 1 of them has a...
