Doing a barn conversion at the moment and the client has built a room which will contain washing machine/dryer but also has a shower. Where he's putting washer/dryer (within 3 mtrs)I've supplied 2 fcu above counter with the intention of outlet plates below.
Customer has seen machines and they have moulded plugs and we have the concern of invalidating warranty.
The machines will be behind cupboard doors (not integrated) and not lockable.
Any suggestions/thoughts.
Should I get him to build small box around socket with a screwed down face and would this comply?
Many thanks
Can't see a problem plugging in behind the appliances.
You'd have to be a right numpty to have wet hands, pull out the appliances and stick your fingers in the sockets!
Tin Hat on!
agree with murdoch. common sense overrules silly regulations at times.
As Einstein said though Murdoch, the only difference between genius and stupidity is genius has limits :)
i'm struugling to find mine.
then they can blank the sockets off, or remove the shower. we can't install for future changes, only to current requirements.
Then the new people will have handy places to install their appliances. You can't really future proof for other people's stupidity mate
My understanding is the idea that removing moulded plugs invalidates the warranty is mince.
Interesting to note the comments so far on complying with the requirements of special locations. It'll be your name on the cert and presumably you'll note any non-compliant work.
