down2earth
Hi all, just moved into a property that has an ornamental lamp post (about 9 ft high) with a big sodium bulb inside. There is an SWA spur nearby on which I have fitted a IP66 socket. My plan is to fit a IP66 FCU from the socket and fuse it down to 3A and then onto the lamp post. My question is, is 3A sufficient, I'm guessing the reason for using sodium bulbs is they are low energy but just wanted to check.
For info the SWA spur is coming off about half way from an SWA run of about 45metres down to a shed. The previous occupant assures me that the junction was done properly and resin filled etc. Ze reading from the spur is .85 which I realise is borderline for TNS.
Thanks for any help
Down2earth
Thanks for any help
Down2earth
