C
Colinmc1
Does anyone know of a soffit vent that can be fitted from inside the loft? It's too high to use a ladder to install one from outside. There is no chimney to vent to and no roof vents.
Get a lap vent mate, you can get them with a 100mm connector, shaped like a wedge goes in between the felt
get a lap vent mate, you can get them with a 100mm connector, shaped like a wedge goes in between the felt
tell me more about these. I've got a job where i casn't get to the soffit coz. Of conservatory.
I have seen myself before now,removing the centre flaps/grille,then lobbing a string out the sofit to the ground, tying the vent on to the string(mastic readied of course) pull it up,then get your pinkies through the hole and squeeze it on and let it set with the string keeping it in place,fit flexible pipe from inside the next day
That was done where there was no possible access place and there was no window near by
If there is a window I do it from inside,H+S freaks would not want to watch
I've just had a look at gazzamikes lapvents www.lapvent.co.uk and gave them a call. They have a product that they refer to as the "extra vent " which comes complete with all the fittings and 3m of flexible hose to connect directly to a fan £76 + VAT + delivery
Pricey on the front of it but sometimes it's worth it rather than balancing on a ladder. I've had to use them recently due to customers house being too high due to a slope
Colinmc1,
gazzamikes,
