J
jimmcf
Does anyone know of a source of a dual socket back box with an extended 'skirt' (see photo)
The broken one is on a concrete wall with the feed through a hole in the wall at the top of the skirting so other options are limited.
Jim
that looks like a standard, surface mount back box that has had some wood fitted around it?
Thanks folks someone's found it for me.
It's a Crabtree 2 Gang 32mm Patress Back Box White. part code 9050.
Thanks especially to Littlespark and Andy 78
Jim
@jimmcf
hope you stick around, there is a treasure trove of info to be found here.
