Discuss SOX replacement in the UK Electrical Forum area at ElectriciansForums.net
drzsta
Wondering what the options are for upgrading/replacing 90w SOX streetlights. All ours are remote control gear in the base of the posts. Pain when you have a dual lantern post with 2 sets of control gear in the base, just no room to get at it without dropping the cuttout and backing plate out complete. :mad:
Has anybody got any recommendations with regards to SON/LED gear to put up?
fit LED units with drivers in the lamp housing.
When I was working in street lighting we generally specified 150w SON as the upgrade for 90w SOX, but as Tel says LED would be the way to go now.
we recently had a son streetlamp fail (right in front of next door's). guys came out, pi$$ed about for 1 hour trying to fix it. i suggested they fitted LED. now we're the only part of the road with decent streetlight. all the neighbours look like essex boys under the lights.
uploadfromtaptalk1455048541969.jpguploadfromtaptalk1455048586034.jpguploadfromtaptalk1455048643068.jpg
Reply to SOX replacement in the UK Electrical Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi all, I have a regular client who has asked for a battery back up system to be installed at their home. They live in a rural location on a...
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
What is the oldest dimmer switch you have seen in use recently? When did you install your first dimmer? (Veteran sparks only) I ask because a...
Hi guys...I'm not a spark but can I ask your advice. We have 6 GU10 halogens in our kitchen...they use a lot of electricity and I would like to...
13K
