All this pretending that nothing can possible go wrong for a plumber, whereas thousands of lives depend on every single move a sparky makes is a bit silly no?
If something leaks from an electrical circuit the RCD shuts it out. No RCD? the mcb will usually get it before it gets bad. Ok so a loose joint on a high current circuit can potentially start a fire but even this is VERY unlikely. If somone gets a belt off an RCD'd circuit the chances of it doing them any damage or even hurting are virtually zero.
Ok so someone could pull the main fuse out and stick a finger in the live incomer whilst they got they're tongue on the earth block it might do some damage but this isn't a sparkies problem.
If a plumber has a leak or a connection pop under pressure after they leave a job there is no such safety cut out systems in place to protect the tens of thousands of pounds worth of property that could be damaged.
Its all very well saying "we're better because electrics kills so there" but that would make the monkeys who work in kwikfit SIGNIFICANTLY better than us sparkies because cars kill by the thousand.
A debate about 'who is better, plumbers or sparks?' is akin to 'who is better, my dad or your dad?'
Well mine obviously.
