Early on in my appreticeship, I was told by my boss that a good engineer can turn his hand to anything. He was right.
not quite right. i tried turning my hand to adult movies. i was a complete flop
Nowadays there's a little blue coloured pill to sort that problem for you.
The difficulty lies in getting it through the hole in the end !!!
Unless of course you throw away your old fashioned water gauge & buy a hi-tech electronic one & what about the Flue Gas Analyser ??? ;)
What about it? If people aren't getting a yearly visit from whoever their body is, then I don't reckon many will be having these things annually checked. I know personally of 3 who don't.
But isn't that because of an appliance not combusting or venting correctly that can cause CO deaths?
Not actually the gas installation work and testing
All this pretending that nothing can possible go wrong for a plumber, whereas thousands of lives depend on every single move a sparky makes is a bit silly no?
If something leaks from an electrical circuit the RCD shuts it out. No RCD? the mcb will usually get it before it gets bad. Ok so a loose joint on a high current circuit can potentially start a fire but even this is VERY unlikely. If somone gets a belt off an RCD'd circuit the chances of it doing them any damage or even hurting are virtually zero.
Ok so someone could pull the main fuse out and stick a finger in the live incomer whilst they got they're tongue on the earth block it might do some damage but this isn't a sparkies problem.
If a plumber has a leak or a connection pop under pressure after they leave a job there is no such safety cut out systems in place to protect the tens of thousands of pounds worth of property that could be damaged.
Its all very well saying "we're better because electrics kills so there" but that would make the monkeys who work in kwikfit SIGNIFICANTLY better than us sparkies because cars kill by the thousand.
A debate about 'who is better, plumbers or sparks?' is akin to 'who is better, my dad or your dad?'
Well mine obviously.
Unless the installation wasn't installed with regard to the correct siting/fitting of the flue or taking into consideration ventillation issues.
What is not often appreciated is the fact that a very sizable chunk of the training & assessment that needs to be undertaken in order to become qualified to work on gas appliance relates to flueing & ventillation.
(where's Chris Murphy when you need him ??!!)
Exactly !!
There are good, bad & indifferent in all trades & professions.
Thats fair enough Geordie.
I don't want people to start thinking I'm arguing who's better, not all that bothered TBH. Its more a little banter
I agree with you. I'm old enough & I hope wise enough to recognise an argument when I see one.
so far, I haven't seen one & I enjoy the banter here. :)
Im jealous of plumbers and plasterers. Plumbers because generally the customer is really happy to see them as they are there to fix a leak or get the heating going - plasterers as once they finish the place looks completely transformed. Nobody seems that amazed when you've messed around getting 10 downlights to switch in sections, and from about 4 different points - is it just me or does nobody just want all the bloomin lights to come on all at once anymore??!!
