Discuss SPDs do i need to fit them? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a new circuit in domestic dwellings for various housing associations my question is do I need to fit an SPD or would it be the responsibility of the housing association, the circuit supplies equipment in the garden I'm running a 2.5 twin and earth through the house fed from a B16 MCB or RCBO depending on the fuse board it goes to an external rotary isolator, thanks in advance for your replys
Boing said Zebedee.
Running a 16A radial to an external location…. To a rotary isolator?
What the heck for?
Run to an external socket maybe.
Are the housing associations providing hot tubs now?
Possibly Air Source Heat Pump now I think of it
I've just been doing a SPD risk declaration and getting the customer to sign. I'm doing these for new circuits and alterations. It's only a couple of tick boxes no calculations. It also prompts thought about what type is required.
Reply to SPDs do i need to fit them? in the UK Electrical Forum area at ElectriciansForums.net
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
Got my 18th Ed certificate late last year, now doing 2391. Obviously Amendment 2 has come out since then, and I see these courses available to...
8K
  • Locked
5K
Hello, I have a Clipsal consumer unit with two "ways" unused and blanked off and potentially a third available as the Proteus Geyer B16 MCB is...
4K
Am I on the right lines, I ask? I've just recently moved into this house which is nicely equipped with a large 15 circuit CU unit with a split...
