E
elsparko
you cant get level 3 without experience in fault finding.I mean depends who u got taught by. We learnt nothig about water spillages etc.. all ik is open or short circuit. Would need more experience on fault finding field
ik we had an exam but the teaching was so little, we did short circuit and open circuits, the problems were like loose cable, need to replace cables etc.. idk about water spillagesyou cant get level 3 without experience in fault finding.
From your profile you say you have a level 3 C&G 2365, I think. Not withstanding you may be in training, you seem to have little grasp of things (with regards your problem), an I'm not trying to be belittling?
Has the OP actually tried resetting the rcd? sometimes they trip but the switch sometime doesn't indicate a trip, worth physically operating the switch to see if it resets, just saying.Water or tea in a socket is very unlikely to be able to cause enough fault current to blow a fuse or trip an mcb, but could easily trip an rcd.
If nothing has tripped Something else must have happened to cause another fault that has resulted in an open circuit on one or more of the circuit conductors probably at or before the first non working socket.
Crikey Middy that was at 5:15 can't remember that far back, seriously no I think it was a case of wayward fingers, sorry if I confused you Mate.Pete did you say something (#35)?
Why the optimistic tag Ant?Crikey Middy that was at 5:15 can't remember that far back, seriously no I think it was a case of wayward fingers, sorry if I confused you Mate.
Not the first time, must be lack of no tool in hand.Anyway still doing the help the aged work.Why the optimistic tag Ant?
If I was level 3 I’d be going back to level 1....if i had lvl 3 id be embarassed to ask this...
