M
michael_brooke
Hi guys and girls
Can i transform a 230v downlighter to 12v using a transformer that has a gu10 lamp or does it have to been a 12v dowlighter that uses mr16 lamps
Is it fire rated downlight?
I can't see an issue with changing the gu10 fitting with mr 16 push in type?
what's the reason ,may I ask?
Depends on the make, but you should be able to change the lamp holders and convert, again though why?
There are 230v downlighters in a bathroom just wanted to transform down to 12v without changing lamps,leds require a driver but can u transform down gu10 to 12v
Still need to change lamps, the LV transformer you need for 12v will be fine for 12v led mr16s as long as you don't dim them
You can get LED lamps with a GU10 connection...............no need for a driver it is integral
Didnt think you could use led lamps with standard transformer do leds not have to be wired in series or parallel
