that's for the circuit T/E. the flex to each light needs to be rated for only 1 fitting.
You're out of date Kingeri
1mm is the minimum for lighting now (1.5mm for everything else).
Laurie
Then a length of 2-core 0.75mm heat resistant flex (about 9-12" normally) from each JB to each downlight.
[/QUOTE]
Reg number for this? You can happily supply a fixed load with an appropriately rated cable. The 0.75mm flex is feeding only one light fitting.
Spotlights and kingspan insulation
smiffy911,
kingeri,
