Discuss Spur off ring. C2 or C3. in the UK Electrical Forum area at ElectriciansForums.net
G
graham123
Two twin sockets spured off ring main in a 2.5mm t+e. just straight from ring no 13a fused spur. I know you can have one twin socket. Would you C2 as potential to overload the CCP of the radial with 2 twin sockets?
tend to agree with wirepuller here. all depends on the probable use.
Reply to Spur off ring. C2 or C3. in the UK Electrical Forum area at ElectriciansForums.net
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi everyone, I've got an electrical ring circuit that looks somewhat like the drawing below, where the blue sockets are part of the main ring and...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
