Coach or carriage bolt,is correct,together with many other local and foreign terminology,some hailing from the transport job,some the building job,and extra terminology we took up,during input from overseas suppliers,such as during and just after WW2.
A coach set screw,is threaded the entire length,a coach bolt,has a plain shank,and is threaded for a percentage of it's end,10-25%.
Timber fixings,may still be described as either bolt or screw,but with a parallel or tapered wood type thread,will have a means of driving,such as a square,hex or internal driving form.
Gutter bolts are of small diameter,and have a slot or cross-slot,usually to hold the bolt,whilst tightening was achieved on the square nut.
I have an extensive library of engineering books,including standardised thread form history,and a series of Buck and Hickman catalogues,in mostly hardback,from the 1800'S to mid 70's.
So,anyway....that's what i spent me time do'in...whilst the rest of you were testing beer and honing chat-up lines...:p
‘Screws ‘normally have threads the full length. So a hex head bolt with full threads is actually a SET SCREW. Normally called ‘hex set’
If it has a shank (non threaded part) it’s a BOLT
That’s how I was told in my first job in a engineering stores.
It may or may not help to solve this riddle!
Hmm.
Coach bolts (which is what I would call them),
Carriage bolts,
Cup head bolts,
Mushroom head bolts.
Tapered bolts that you screw into wood, are called lag bolts, lag screws or coach screws.
I just had a peep at a listing from Nettlefolds,who were one of our longest standing engineering manufacturers of fixings.
Although looking identical,they list "Carriage Bolts" and "Cup Square Bolts" as different items.
Carriage Bolts,are listed up to 7/16" diameter and 16" long,and have no B.S.S number.
Cup Square Bolts,are listed up to 1 1/2" diameter and 12" long (additional lengths on request) and have a B.S.S number for both bolts and nuts,that is,an engineering specification in terms of strength and conformity,for use in engineering applications.
Anybody who has any questions regarding their selection of moulders brads,clyde dog eared steel brobs,or wrought iron holdfasts...just send me a telegram :)
(I have the telegraph and cable order code documents,which are fascinating...£40 in 1886,was coded "ketchup" ;) seems a long way from Skyping me pal in New Zealand,on an S9...)
I thought they were called M6 roofing bolts.
Usually roofing bolts don't have a square shank, but rather have slots on the dome head so a tool can be used to stop them turning rather than relying on the square shank pulling into the timber. This said I have heard, the terms coach, carriage, roofing, dome head... for all sorts of similar bolts and screws.
I guess its probably down to what ever is the most common traditional term local to your area.
here you go. square heads. :
images
