Discuss Staircase Timer Switch on LEDs in the UK Electrical Forum area at ElectriciansForums.net
If the load decreases from above the permitted load the it proves the switch works with the lower loading.
Then you can come on to the forum and ask about switches.
That's good of you.What do you suggest he does regarding the light that is now not working?
Purchase a different switch that works with a higher load rating, jeeez some of you lot need some major hand holding, see my Youtube channel on how to use a right handed screwdriver and lessons on how to chat women up.
Reply to Staircase Timer Switch on LEDs in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Hey all, hoping someone can help with a particularly annoying problem! Have changed a load of LED downlights to the fixed bulb Centorio type (14W...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
I have installed a number of 120v smart light switches and smart bulbs which I have set up on a schedule via an app. I would like to add another...
