Discuss star and delta motor connections in the Australia area at ElectriciansForums.net
can anyone help, what is the difference between delta and star motor connections?
This subject has been covered many times on several Forum threads. If you scroll down this page till you find ''Similar Threads'' you will find explanations. You can also go to the Commercial/Industrial Forum on the Index page and look at Tony's stickies...
It's always best to have a look around at previous threads on the forum concerning any question you may have. There is a very good chance that you will find the answer your looking for, among those older threads and posts....
Reply to star and delta motor connections in the Australia area at ElectriciansForums.net
What tests and certification do you do for motors supplied via a motor control panel, DoL, soft starts, VSD, star delta, etc?
Hi Changing a 3 phase star delta motor and replacing with a dol 3 phase motor. Would i be right in thinking I can remove 3 of the 6 cables at...
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
Hi. I need to alter the configuration of this motor wiring from star to delta so that I can use a VFD to control it (hopefully). If I remove the...
