T
theatrespark
Does anyone use a ready-made tool for cutting steel Adaptaflex / Copex? If so, where is an affordable place to buy one? Thanks.
The best thing I have found by far is a hacksaw. Make a wooden jig to hold it tightly lengthways with a nice slot in the middle to cut through.
Reactions: 1 person
to be honest the steel is that soft, chop through it with hacksaw or use a knife and snips
(is this the completely steel version or steel spiral inside plastic?)
use a hacksaw and cut at 45' angle across 3 rings on adaptorflex, untwist. perfect cut everytime,no need to use snips.
Reactions: 3 people
I find a fine toothed blade easier than a coarse one.
bassically 32tpi blade
we usually use 24tpi for everything.
18tpi is best for strut
32tpi is best for tray etc
Reactions: 1 person
I use the vice on the hilmor bender and a hacksaw. Or a blunt set of snips
I have Stanley yellow toolbox which comes with a inset groove in the lid... slap it in and junior hacksaw, clean and easy cut everytime....I use loads of it and never need any fancy gear.
Reactions: 2 people
In truth,the better your technique,in using a hacksaw,the less fancy jigs you will require. Good quality blades,TPI to suit material type and size,slow start,full strokes in use,control at finish...
Base skills,that i find myself explaining to lads who did their apprenticeship/training,years back....just don't lend em' your best all-hard blades...:yes:
Reactions: 1 person
I squeeze and twist the Kopex, to open up the spiral where I want to cut.
Then use some tin snips.
Takes about 20 seconds.
That's exactly how I do it, really easy to do with out buying any extra tools. Nice clean cut and I think it's the safest method also.
Steel Adaptaflex Cutter
theatrespark,
LeeH,
