- Reaction score
- 8,788
Well this is a first.... a fault with Quinetic gear.
Lighting circuit running up to loft, a box with 3 Quinetic dual receivers, and then outgoing cables to all upstairs lights.
When the main switch on the CU is turned on first thing in the morning, one particular switch/light doesn't work.
But turning on another upstairs light and then retrying the original light results in it starting to work.
It happened yesterday and I thought I'd been mistaken as everything worked perfectly all day.
But then the same thing happened this morning. I've checked all connections. The trouble is, once working it stays working making diagnostics tricky.
My plan tomorrow is
-try the switch (hoping it fails)
-check the indicator light isn't showing on the receiver when switch is pressed, proving a quinetic issue.
-try turning the light on using button on receiver.
I just thought I'd see if anyone has ever had a similar fault. I've found the stuff rock solid up until now.
I guess I'd better order a spare receiver and switch....
My plan tomorrow is
