Discuss struggling here. in the UK Electrical Forum area at ElectriciansForums.net
Tel, I'd be interested in seeing the result too if a photo is possible. I have a partially sighted client and I've been trying to convince her to have something similar fitted because her stairs are dark and dingy!
seen that, just what i need, but how do you get to the suppliers site?
that tlc sensor looks good as it will do florries, so i imagine it will be |OK with a transformer load. bit pricey though, £67 + VAT for 2 of the buggers.
There's a couple of mini sensors there, only 45secs delay on it though, guess you could use a couple of them wired to an external timer.
Thats what I was thinking , depends on the room to conceal it though, one of those mini's controlling a timer board as in a bathroom fan.
if you look at the earlier utube post, that's what i want. the lights in the side activating when PIRs trigger. there's 12 steps, so top and bottom step will have the pirs and treads 2-11 will have the 10 LEDs
didn't look at that one as the LED set comes supplied by a 240V tranny, so i need 240V switching PIRs.
that looks the favorite. i've tried phoning and no bugger picks up the phoned. will try again tomorrow.
Reply to struggling here. in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
Hi. I've had an electrician come in to set up sockets and lights in my loft conversion. 2 switches for the main light (one at the bottom of the...
Hi all, I am an experienced DIY electrician and I just wanted to ask a quick question about something since I am new to this forum, if it hasn’t...
