lack of knowledge for me probably just seen no seperate cpc and just said re wire required
Another Mind reader hehe
twin and earth with no integral earth
What concerns me here is that and I quote Light hanging from celiling - worry that it was left like that.
Second and I take it you did a test at that point and that point only with a visual for the rest of circuit. I ask why was the end of line not found and a earth path proved and tested there?? before a judgement call is made??? as we all know there could be many breaks in the conduit corrosion plastic JB with no earth continuity a lose conduit downstream from where you tested which may result in high reading that do not comply and you may still not have a complete and healty earth path.
Just curious
Just because we have a earth present at a 1 point does not mean we have a earth
lol ok you got me twin cable
You have a valid point but on the other hand he may have simply posted an abridged version in the hope of keeping our attention rather than posting I tested at the first light, then another, then another ......then when I found the highest reading of xx I realised this was the last point of utilisationWhat concerns me here is that and I quote Light hanging from celiling - worry that it was left like that.
Just curious
This had a perfectly good earth via the conduit.Honesty is the best policy tell them it doesn't have an earth, tell them the reasons why we now install circuits with earths, tell them that that as long as there is no class one fittings its OK and if there is they could be removed to class 2 rather than rewire.
Yes best practise would always have a flying lead, however if I came accross it on an I&T as long as it had good continuity to fittings would just put it as c3.So the metal conduit is being used as the cpc. If metal fittings were used you would put a flying earth lead from conduit box earth terminal to fitting? Just clarifying as the original posts doesn't say if it is metal or plastic light fittings.
