Discuss Sub Board?? How shall I go about it? in the UK Electrical Forum area at ElectriciansForums.net
Sometimes the odd pic is funny, sometimes it's just makes no sense and is a little strange, but if I'm honest it doesn't really aggravate me.
I do get a bit aggravated by some of the posts I see on this forum, advise and discussion is fine (different opinions and prospective are good) but asking what size cable to use makes a mockery of mine and everyone elses here training.
I enjoy the forums but I get a little annoyed when I feel people are taking advantage, It's basic stuff and if you don't know it you shouldn't be taking on these jobs.
New posts
Reply to Sub Board?? How shall I go about it? in the UK Electrical Forum area at ElectriciansForums.net
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
